The information element Response Variable (identification) from Command processing cannot be translated
Some elements of the response variable from the Command Processing are not translated. This has been fixed.
Some elements such as the variable identification in the Command Processing screen are not translated correctly in the Service Engine. Only the keyword is displayed.
Cause:
Static controls have been replaced with dynamic controls that do not translate.
Solution:
The dynamic text controls that replaced the static text controls are now translated according to the active Service Engine language. The "Translate display text" property is ignored. The controls for locking Users, Lock Code and Comment are not translated for either static or dynamic controls.
The change of the active translation when the command screen is open is now also taken into account.
Item ID: 266484
Version: 12.00 Build: 159727
Version: 10.00 Build: 159736
