The iec870 driver does not set T_EXTERN status bit when receives IO with external real-timestamp
Issue only in 7.10: the IEC60870 Master driver does not set T_EXTERN status bit when receives IO with external time stamp. Thus values with external time have correct timestamp (as sent by PLC) but no status bit T_EXTERN (nor T_INTERN).
now the status bit T_EXTERN is set correctly
issue only in 7.10
Issue Number: 30406
Fixed on Date: 18.9.2013
Versions: 7.10 0 BUILD 7770
