The history of changes may not log a screen element position change in the editor.
Despite the detailing level is set to "object", the history of changes may not log the change of a screen element position when using the "position" properties in the editor.
An issue has been addressed so that the history of changes logs correctly a screen element position change in the editor.
Workaround: If the element position is changed by drag and drop the change is logged correctly.
Issue Number: 35194
Fixed on Date: 9.12.2015
Versions: 7.60 0 BUILD 36068
