The function selection dialog in the editor does not respond anymore under specific circumstances.
It appears as if the zenon editor has stopped responding. The buttons in the function selection dialog no longer react on mouse clicks. Right clicking in the function selection dialog displays the context menu of the detailview behind the dialog.
An issue has been address in editor to process slow double clicks properly so that the function selection dialog can be operated correctly.
As a workaround, pressing "ESC" closes "Select a function" dialog.
Issue Number: 27747
Fixed on Date: 22.11.2013
Versions: 7.20 0 BUILD 17768
The 32 bit editor stops respoding under specific circumstances on creating a Recipegroup Manager function, and may display an error "Encountered an improper argument"
Summary When creating a new function "Recipegroupmanager" and selecting the type "Change recipe state", without any further selection of recipe groups or recipes, the editor may stop responding and display an error message: "Encountered an improper ...
Under specific circumstances some zenon Editor Dialogs were not shown at the correct place.
Summary Under specific circumstances the second dialog for variable import via XML were not displayed at the correctly position. Especially, when using more than one monitor this issue could be occur and the dialog were displayed on the wrong place. ...
Under specific circumstances, it is not possible to select a new screen in the screen selection dialog from the batch control edit tag keyboards properties.
Summary When opening the screen selection dialog from one of the keyboards properties in the batch control module and it is clicked the new screen button in the toolbar, the new screen is created but not displayed in the list. Description When ...
Screen – Execution - Start function. Removing a function link through the "no selection" button in the function selection dialog for a sub-project, that is not loaded, leaves a dummy link to the project.
Summary Removing a function link at e.g. the start function of a screen, through the "no selection" button in the "function selection dialog", where the function is the function of a sub project and the sub project is not loaded, leaves a dummy link ...
Editor may stop responding under specific circumstances when the color picker is closed
Summary When picking the color for a property using the color picker in the properties window under specific circumstances the editor may stop responding when the color picker is closed by clicking on another empty area in the screen Description When ...
