The function for the handling of alarm message list and/or chronological event list printing didn’t work as expected.
The ‘print AML or CEL’ function of the group contains functions for the handling of the alarm message list (AML) and the Chronological Event List (CEL) didn’t work anymore.
An issue was addressed at that specific AML and CEL function. Now, the ‘print AML or CEL’ function works as excepted.
Issue Number: 36409
Fixed on Date: 11.5.2016
Versions: 7.50 0 BUILD 28116
Visibility doesn't work for “Chronological Event List Filter” MDI Element
Description In the screen of type "Chronological Event List Filter" the link to a variable for visibility does not work correctly. In the Service Engine, when a time filter is clicked, the visibility setting no longer works as configured. This error ...
SYSDRV variable ‘Alarm Message List active/inactive’ value is TRUE while AML is deactivated via zenon function.
Summary The System Driver variable ‘Alarm Message List active/inactive’ has value TRUE, also while the AML is deactivated via zenon function ‘Activate/deactivate Alarm Message List, alarm/event groups/classes’ - configured to toggle/deactivate the ...
Alarm Message and Chronologic Event lists visibility may not work correctly in the Runtime.
Summary Alarm Message and Chronologic Event lists may be visible when the value of the variable linked to the visibility property is set to hide before opening the respective screens in the Runtime. DescriptionAlarm Message and Chronologic Event ...
Default names do not work for Time/lot, Alarm Message list and Chronologic Event list filter picture
Summary In 7.20 it was possible to define Default screens for filtering AML or CEL. They were indicated through their special name. You can select the name by opening the combobox of the "name" field in the screen properties. When it was done like ...
With the XML export and import of screens such as Alarm Message list and Chronological event list, the following parameters of the List control get lost
Description During XML export and import of screens, objects of the list control can be corrupted. After the import, the controls "Tap", "Double tap" and "Manipulation" are available, but cannot be operated in the Service Engine (aka “Runtime”). Only ...
