The extended trend screen refresh rate property may not accept a valid input value typed in the editor and runtime.
It is not possible to insert a valid extended trend screen refresh rate in the editor and runtime when typing first the decimal separator (.) so that it is displayed a warning message.
An issue has been resolved so that the refresh rate input range is only checked after changing the active tab or pressing the OK button in the extended trend filter dialog in the editor and runtime. Workaround: To type a zero (0) before the decimal separator (.).
Issue Number: 29778
Fixed on Date: 11.12.2015
Versions: 7.60 0 BUILD 36068
