The Equipment modelling cannot be accessed via the zenon API on a WebClient
When accessing the equipment model on a webclient, the SystemModelManager
returns a "DISP_E_MEMBERNOTFOUND" Exception
An issue has been addressed in the Webclient where the SystemModelManager was not available. Now the SystemModelManager can also be accessed via the API on the webclient
Issue Number: 28823
Fixed on Date: 14.2.2013
Versions: 7.00 0 BUILD 7
Set colors of color palette to zenon elements via API.
Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
Engineering Studio crashes when modifying the equipment model by drag&drop
Description The zenon Engineering Studio was closed unexpectedly when the equipment model was modified by copying of elements and afterwards dragging & dropping of elements. The issue has been addressed and the equipment model can be modified via ...
IIoT Services API delivers the wrong report parameter data type, equipment tree nesting or time filter granularity when the report parameter name contains an underscore
Description In the Report Engine, a parameter name with an underscore is used in a report. If this report is deployed with the "Available in IIoT Services" option active, the IIoT Services API returns the wrong report parameter data type, the wrong ...
Acknowledgement of alarms limited to equipment groups does not work if the user data comes from an external identity provider (AD, Identity Service)
Summary The acknowledgement of alarms that are restricted to system groups does not work if the user data originates from an external identity provider such as Active Directory or Identity Service. This error has been fixed. Description In AML, the ...
Password change at first user logon works via operating system but not via zenon SE ; no AD login possible
Description In the Edge Gateway frontend, the user password can no longer be changed in MS Active Directory, when the zenon system is not a member of the domain. Despite correctly entering the previous password and the new password including password ...
