The Editor may close unexpectedly when renaming a project with VBA disabled.
The Editor may close unexpectedly after renaming a project through the project tree or the properties window when VBA is disabled in the zenon6.ini file.
The issue has been fixed so that the Editor no longer closes unexpectedly when renaming a project with VBA disabled.
Workaround: To enable VBA via the zenon6.ini before renaming the project.
Issue Number: 37098
Fixed on Date: 22.11.2016
Versions: 8.00 0 BUILD 46644
