When using block array variables at a RGM recipe group, and deleting the block array variable with index 0 from the group, and adding the block array variable again, the editor closes with an unhandled exception.
An issue has been addressed with adding block array variables to an existing recipe group. The editor now no longer closes. In order to restore the deleted indices for a block array variable at the recipe group, all variables need to be removed and the block array needs to be added again.
available from 7.0 SP0 build 1
