The default Namespace Index used by the zenon OPC UA server is not entered in the server Namespace array which may lead to OPC UA clients not being able to browse the OPC UA server address space
OPC UA clients that browse an OPC UA server address space based solely on the entries in the server namsespace array may not display any results following the browse of the server. An example of such an OPC UA client is the OPC UA client in WinCC.
By default the OPC UA server uses the namespace index 80 for the sub-folders under objects and also as the default for variables when the OPC UA server is started without explicit configuration. The Namespace Index 80 is also used as the default when explicitly adding variables to the configuration. The Namespace Index 80 however is not added by the zenon OPC UA server Namespace Array variable.
An issue has been addressed in the zenon OPC UA server where the server Namespace Array variable does not contain the default namespace index used by the OPC UA server.
For the situation where there is no existing (old) configuration, the OPC UA server will now use the namespace index "2" for folders and variables. The namespace index in this case can also no longer be changed in the configuration when explicitly adding variables. The server namespace array contains an entry with the index 2 for the zenon OPC UA server. When the configuration in this situation is saved, an entry "CONFIGURATION_VERSION=2" is stored so that after a restart with an existing configuration this is recognized as a new configuration and the OPC UA server starts with the new default behaviour.
For the situation where there is an existing (old) configuration, the behaviour of the OPC UA server remains unchanged to maintain compatibility with existing configurations.
Issue Number: 33243
Fixed on Date: 15.6.2015
Versions: 7.20 0 BUILD 20544
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
    • How to setup the zenon OPC UA Process Gateway with a self-signed certificate
      This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
    • How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
      This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
