The combobox/listbox element doesn't select the correct state under specific circumstances
When using a Combo\Listbox element with a float variable, the enrtry at the Combo/Listbox is not correcly selected in the runtime to match the corresponding value.
An issue has been addressed in the value matching of the Combo/Listbox in the runtime where due to a rounding error the value was not correctly matched to an entry at the Combo/Listbox
Issue Number: 29634
Fixed on Date: 28.5.2013
Versions: 7.00 0 BUILD 10
