The Combo/Listbox does not correctly consider the linear value adustment when writing a value
Writing a value through the Combo/Listbox does not consider the linear value adjustment. With a PLC range from 0..1000 and a zenon range from 0..100, writing a value of "10" writes "10" instead of "100".
An issue was addressed in the Combo/Listbox where the linear value adjustment was not correctly considered. Now writing a value from the Combo/Listbox correctly considers the linear value adjustment.
Issue Number: 28666
Fixed on Date: 22.1.2013
Versions: 7.00 0 BUILD 6
