The COM tab of the driver dialog should support a selection from 1 - 256 serial interfaces.
In the COM tab of the driver dialog it should be possible to select between 1 - 256 serial interfaces.
This issue has been addressed by expanding the selectable COM lines from COM1 to COM256
The range of possible COM interfaces of the following drivers was NOT extended: FpcDrv32
SAIA2ND32
SAIA_Directly32
S5PG32
EIBV2_32
Kieback
SAIA32
SigmaLasal32
S7_200
Issue Number: 36542
Fixed on Date: 2.6.2016
Versions: 7.20 0 BUILD 28665
