The columns in the Listcontrol of Alarm Message List and Chronological Event List cannot be arranged if the runtime files are created for 7.20
The column headers of configurable lists in the Alarm Message List and the Chronological Event List cannot be configured in the Service Engine under certain conditions. This bug has been fixed.
In AML and CEL, the columns of
configurable lists cannot be edited if the Service Engine files were created
for a zenon version prior to 8.20 and the Service Engine is started in 8.20 or higher. The "Freeze column location" property in
Engineering Studio has been deactivated. Configuration should therefore be
possible in the Service Engine.
Note: The name of the property in the Engineering
Studio up to version 7.50 is "Make Header editable".
As of version 7.60, this property was split into "Freeze column location" and "Disable sorting".
This bug has been fixed. The column headers of
configurable lists can also be edited in higher versions if the Service Engine
files were created for versions lower than zenon 8.20.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 8.10
or higher.
Item ID: 282214
Version: 14.00 Build: 239777
Version: 12.00 Build: 241649
Version: 11.00 Build: 242382
Version: 10.00 Build: 243056
Version: 8.20 Build: 250795
Version: 8.10 Build: 333965
[MSI Interface] Deleting an Alarm Event Group prevents sending of Exception Messages
Summary In the Werum MSI Interface, deleting an alarm/event group leads to an error under certain conditions. This has been fixed. Description In the MSI configuration an alarm/event group is used to define an exception message. Later, a group is ...
The function for the handling of alarm message list and/or chronological event list printing didn’t work as expected.
Summary The ‘print AML or CEL’ function of the group contains functions for the handling of the alarm message list (AML) and the Chronological Event List (CEL) didn’t work anymore. DescriptionThe ‘print AML or CEL’ function of the group contains ...
FAQ: How can I backup the Service Engine data, the data created during Service Engine?
The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
With the XML export and import of screens such as Alarm Message list and Chronological event list, the following parameters of the List control get lost
Description During XML export and import of screens, objects of the list control can be corrupted. After the import, the controls "Tap", "Double tap" and "Manipulation" are available, but cannot be operated in the Service Engine (aka “Runtime”). Only ...
Visibility doesn't work for “Chronological Event List Filter” MDI Element
Description In the screen of type "Chronological Event List Filter" the link to a variable for visibility does not work correctly. In the Service Engine, when a time filter is clicked, the visibility setting no longer works as configured. This error ...
