In Batch Control, when enabling or disabling the "changeable in control recipe" property of a tag in an operation template´s phase, then the property is not updated in operation instances that have already been created earlier.
The same issue also exists for the "changeable in control recipe" property of a phase´s minimum execution time.
The described issue has been addressed. Now, these properties are synchronized between operation templates and their instances. To indicate changes, they even have a a status indicator (changed/unchanged) and a reset button in the operation instance´s phase.
Issue Number: 27029
Fixed on Date: 30.5.2017
Versions: 7.60 0 BUILD 36068
