The build setup does not install the IEC62056V.DLL file.
This file is required by the IEC62056 driver in the editor, to allow configuration of the the IEC62065 address, as an alternative to the variable name, and in order to configure the driver specific variable parameters for the timestamp: IEC62065 Time adjustment and IEC62065 Time Interval.
When this file is not available, the driver specific variable properties for the timestamp and the IEC62065 address, cannot be configured. The default values will be used instead, and the variable name will be used as the datapoint name.
An issue was addressed in the build setup, the IEC62056V.DLL is included and will be installed with build setups from 7.00 SP0 build 10 and higher
