The build setup does not correctly update the zenonvstaproxyXXXX files the pipeline directory
The build setup contains the zenonvstaproxyXXXX.dll files however does not correctly update the existing files on installation.
 An issue was addressed in the build setup where the zenonvstaproxyXXXX.dll files were not correctly installed. Now the files are copied and the vsta.exe is called during the build setup process to update the VSTA pipeline directory.
Issue Number: 30074
Fixed on Date: 30.7.2013
Versions: 7.10 0 BUILD 6919
