The build setup closes without a message if it is executed on a system without zenon installed
When executing the build setup on a system where no zenon is installed, the setup extracts but after successfull extraction the setup closes again without a message.
An issue was addressed in the build setup where the setup closed without showing a dialog that no zenon version to update was found. Now a dialog is shown.
Issue Number: 30069
Fixed on Date: 30.7.2013
Versions: 7.10 0 BUILD 6919
