When using the Batch Control Recipe Editor it is possible to configure a special layout with the three available recipe lists. This layout should be remembered and applied again, when the Batch Control screen is opened the next time. In zenon 7.50, however, this does not happen. Instead the recipe lists are always closed when opening the Batch Control screen.
An issue was resolved where the configuration of the layout of recie lists in the Batch Control recipe editor was not remembered correctly. After the fix, the behaviour is the same as in zenon 7.20 - the configuration is correctly stored when leaving the screen and applied when opening the screen again.
Issue Number: 35247
Fixed on Date: 8.4.2016
Versions: 7.50 0 BUILD 27465
