The application instance certificate generated by the zenon logic OPC UA server is incorrect
The application instance certificate generated by the zenon logic OPC UA server on first startup is incorrect. The certificate does not include a subjectAltname field containing the application Uri and DNS name of the OPC UA server
An issue has been addressed where the zenon logic OPC UA server did not generate a correct application instance certificate. Now the certificate correctly contains the subjectAltName field with the corresponding information.
Issue Number: 34115
Fixed on Date: 18.11.2015
Versions: 7.60 0 BUILD 36068
