The ALC.xml file does not contain the linked NodeID for ALC link elements when the link is used in another screen
When an ALC "link" element is used in different screens, on one of the connected lines, the linked NodeID information is missing in the ALC.xml.
An issue has been addressed in the generation of the ALC.xml file where the ALC Links were not added for all lines. Now all NodeIds are correctly inserted into the ALC.xml file.
Issue Number: 29431
Fixed on Date: 23.4.2013
Versions: 7.10 0 BUILD 6571
FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
Visibility lost after Importing Screen XML file
Description During XML import of screens, already existing elements sometimes lose their visibility settings. Linked variables for controlling visibility are not applied. These settings need to be reconfigured. This behavior has been modified. ...
When using Variables.SingleExport(), the exported file does not contain all elements of structures or arrays
Summary When using Variables.SingleExport(), the exported file does not contain all elements of structures or arrays. When importing the file back, the editor does not read back all settings which were made specifically for the elements. The export ...
Combined elements which are included in symbols cannot be used for ALC Aliases
Summary If a symbol contains a line it can be used for an ALC Alias, a combi-element – cannot (is not present on the list). DescriptionIf a symbol contains a line it can be used for an ALC Alias, a combi-element – cannot (is not present on the list). ...
FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
