The AccessSNMP process gateway does not work correctly in zenon 7.10
The AccessSNMP process gateway does not work in zenon 7.10. The Windows SNMP service does not load the accesssmp.dll as an extension agent.
An issue has been addressed in the 7.10 accesssnmp.dll where the Windows SNMP service could not load the dll as an extension agent. Now the Windows SNMP service can load the dll as an extension agent and the AccessSNMP process gateway is working correctly.
As a workaround it is possible to use the AccessSNMP process gateway from version 7.00 instead, with a 7.10 runtime.
Issue Number: 30075
Fixed on Date: 7.8.2013
Versions: 7.10 0 BUILD 7192
    • Checklist: Process Gateway cannot start
    • Checklist: Process Gateway cannot establish a reliable communication
    • AccessSNMP: Process Gateway with support for SNMPv3
      Summary Process Gateway SNMP_SG supports SNMPv3. Description The new Process Gateway SNMP_SG includes the following functionality: Support for SNMPv1, SNMPv2 and SNMPv3. Configuration for a zenon project. Values of the configured variables can be ...
