The AccessDNP3_SG DNP3 Outstation does not correctly set the value of the variable linked for a binary output with control model activation and deactivated command routing
With the AccessDNP3_SG DNP3 Process Gateway and a binary output, configured for the control model "activation" and command routing deactivated, the process gateway sets the value to "0" and does not build a pulse when the master performs a latch off.
An issue has been addressed in the AccessDNP3_SG process gateway, where the value written to the variable in the service engine for a binary output with control model activation, did not build a pulse correctly when the control model activation is used and the master sends a latch off.
Issue Number: 228322
Fixed on Date: 1.10.2020
Versions: 10 0 BUILD 83962
