The 3S_32 driver does not communicate with a PLC in the zenon runtime.
The 3S_V3 driver does not communicate in the zenon runtime. The process variables of the 3S_V3 driver do not show a value in the numerical elements in the zenon runtime.
This issue has been addressed by adding a checkbox for using Motorola byte order instead of Intel byte order for the communication of the 3S_V3 driver.
Issue Number: 34919
Fixed on Date: 2.11.2015
Versions: 7.20 0 BUILD 22047
    • Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
