Terminal Server registration does not work when executing the registration via command line
Registering zenon as terminal server via the button in the startup tool will cause zenSysSrv to start as a service. However, when executing C:\Program Files (x86)\Common Files\COPA-DATA\STARTUP>zenon_startup.exe -reg in the command line, zenSysSrv will be started normally and therefore using zenon in a terminal server environment will not work correctly.
The described issue has been fixed by adding a procedure to the command line registration that has already been used in the registration via the button. zenSysRrv will start as a service when there are appropriate settings in the zenon6.ini ([TERMINAL] Client=1 and Serialize=1)
Issue Number: 32942
Fixed on Date: 29.10.2014
Versions: 7.11 0 BUILD 16009
