T5BusIec850s.dll IEC61850 Server does not set PurgeBuf=False after purging BRCB buffer
Buffer is purged immediately after getting request.
Issue Number: 248468
Fixed on Date: 14.2.2022
Versions: 8.20 0 BUILD 95599 | 10 0 BUILD 97200
IEC61850 Server resets EntryID by any purge of BRCB
Summary The IEC61850 Server - I/O driver in zenon Logic - resets EntryID to 0 when received purge for BRCB - when client writes */PurgeBuf[BR]=true in this BRCB. It causes that when client purges buffer frequently the Server uses for new Reports the ...
Checklist: OPCDA Server
Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Do NOT use DCOM in combination ...
FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
Checklist: Client/Standby cannot establish a reliable connection with Service Engine Server
Bug: Write Error to setVal[SP] on IEC 61850 Server
Description The IEC 61850 Server fieldbus driver accepts the write requests for read-only ('RO') data attributes (variables) with FC=SP; e.g. */setVal[SP]. And it refuses the write requests for data attributes with FC=CF, if SCL-configured as 'Set' ...
