T5BusExopcua_s: writing a string variable from an OPC UA client takes over the value the first time but not on subsequent writes
If an OPC UA client writes a value of a READ/WRITE
string variable to the zenon Logic Service, the value is only written at the
first write operation. In subsequent write operations the value is no longer
taken over.
This error has been fixed. The value is
now taken over with every write operation.
- Update your zenon Software Platform to the
latest build of zenon 11 or higher.
Item ID: 260430
Version: 11.00 Build: 117823
OPC_UA client bug with STRING TYPE
Description The OPC UA Client driver was updating STRING variables periodically, instead of on value change. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software Platform to the latest ...
