The EtherNet/IP Adapter (T5BusEIPS ) does not close TCP connections when these are idle and do not send any data. This can lead to a denial of service for valid EtherNet/IP Adapter when the maximum number of 124 TCP connections are used by (other) non-EtherNet/IP clients.
The issue has been addressed. The EtherNet/IP Adapter (T5BusEIPS) provides a new configuration option "Inactivity Timeout (s)" to automatically close idle TCP connections on port 44818. By default, the inactivity timeout is disabled with a value of -1. When a timeout value >0 is configured, the oldest TCP connection on which no data was received is closed after the timeout time, when reaching the maximum limit of 124 TCP connections.
Item ID: 286897
Version: 14.00 Build: 293273
Version: 12.00 Build: 301428
