The EtherNet/IP Adapter (T5BusEIPS) does not make use of TCP keep alive messages to check if the TCP connection from an EtherNet/IP Scanner is still OK. The issue has been addressed and the T5BusEIPS enables a TCP keep alive for the listening socket 44818, to clear TCP connections that are no longer available. The default timeout settings of the operating system are used for the TCP keep alive, that may be adjusted according to the configuration needs.
Item ID: 286895
Version: 14.00 Build: 293273
Version: 12.00 Build: 289185
