"System ID" was incorrectly used for "System Number" in the SAP interface
In the SAP interface there exists a property called "System ID" which actually refers to the SAP "System Number".
The incorrect naming of the property has been corrected. After the fix, the property is correctly named "System number".
This Knowledge Base entry refers to the property name in the English version only!
Issue Number: 23534
Fixed on Date: 3.7.2013
Versions: 7.10 0 BUILD 6919 | 7.11 0 BUILD 10238
Checklist: SAP Interface does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
[SAP Interface] Values of export parameters of SAP function are not assigned to variables
Summary Two bugs occur in the SAP Interface: In the Service Engine, zenon variables are not updated correctly. And in the Engineering Studio, import/export parameters are swapped when importing RFC function configurations. These two bugs occur ...
Modifications in the SAP interface module are not recognized by the reload function
Summary When the SAP Interface module is used in a zenon project, and the configuration in this module is changed in the zenon editor, creating runtime files will cause the file sap.cmp to be updated. When the function "reload project" is then ...
After startup of the runtime, incorrect measurement readings may be sent to the connected SAP system
Summary In a project where measurement readings for SAP are configured, it can happen, that a value will be provided to the SAP system after a runtime start, before the variable value is actually available in the system. As a result there are ...
SAP maintenance reports don´t work
Summary In the module SAP interface it is possible to define maintenance reports. They actually use the SAP function blocks ALM_PM_MAINTNOT_CREATE ALM_PM_MAINTNOT_SAVE ALM_PM_MAINTNOT_MODIFY_DATA These are, however, not remote enabled with a ...
