SYSDRV - The setting "Only read from standby" is not activated when changing the System driver variable type in the variable properties to one which is specifically designed for use on a Standby Server.
Changing the System driver variable type via the variable properties to one which is designed for use on a Standby Server now correctly considers the setting "Only read from standby"
Issue Number: 31287
Fixed on Date: 19.3.2014
Versions: 7.20 0 BUILD 17768
