SYSDRV "[Project summary] Input set value: Current default set value" variable inconsistent values over Logic Service to Service Engine connection fieldbus
In zenon the system driver
variable "[Project summary] Input set value: Current default set value"
does not correctly transmit values that are shared with zenon Logic
via shared memory. If values are changed,
the previous values are still sent via the fieldbus of the Logic Service to
Service Engine connection.
This error has been fixed. Shared values are sent
correctly again.
Item ID: 269648
Version: 12.00 Build: 180966
Checklist: The Logic Service to Service Engine connection does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
