HEADER AND GRID
The properties for Header and grid are now displayed consistently.
COLUMN WIDTH FOR LISTS
For configurable lists, the new property Unit for column width can be used to select for configuration between characters or pixels.
Note: Already configured lists from projects from previous versions are not modified in the current version. Existing values are adopted.
HEIGHT FOR IMAGES
The height of images in cells can now be customized in the properties Image height and Height [pixels].
Note: In previous versions, images were always scaled with the width, but circle symbols were cropped. Now circle symbols are treated like screens.
VERTICAL ALIGNMENT OF COLUMNS
The vertical alignment of the contents of columns can now be defined for configurable lists. The new property Vertical alignment has been implemented for configuring the alignment.
