The action "switching command" (former "double command") on variable with "Select before Operate" and in group with property "watchdog timer" = "none" counts in background after execute 2nd stage. Then when the device (IED) delays command termination can cause blocking situation in zenon command processing. Issue reproducible only in case of SBO use since implementation of "auto-remote" action type.
Note: the action "auto-remote command" has to keep supervising SBO process until command execution termination, but not other action types.
Now if the execute fails & negative respond from IED or action timeout - an error message is logged with failure reason and handling object ends.
