In zenon redundancy, the Standby Server may
freeze if the Server fails and an archive capsule with Swinging Door
compression active needs to be completed during the network timeout period. The cause is that the archive capsule cannot read the file.
This error has been fixed. Swinging door compression is completed correctly and the Standby Server is upgraded to a Server as expected,
