STRATONRT: log CPU utilization warnings and errors only when the value has exceeded the previous maximum
The zenon Logic Service permanently logs CPU usage warnings and errors every 5 seconds, even if the value does not modify.
This behavior has been corrected. CPU utilization messages are now only logged when a new value occurs. Lost PLC cycles are still logged as soon as they occur.
  • Update your zenon Software Platform to zenon 12 or higher.
Item ID: 266149
Version: 12.00 Build: 162090
    • S7TCP Driver has a higher CPU utilization in zenon 12 than in zenon 11
      Description The S7TCP driver utilizes the CPU in zenon12 more than in previous versions. This behavior has been modified. The CPU utilization by the S7TCP driver has been reduced for zenon version 12. To benefit from this fix: Update your zenon ...
    • S5 TCP\IP has a higher CPU utilization in zenon 14 than in zenon 7.50
      Description The S5 TCP\IP had a higher CPU utilization in zenon 14 than in zenon 7.50. The issue has been addressed and the CPU utilization is now less than before and does not require the full performance of the core, when it is not needed. To ...
    • OMRON_EIP, LOGIX_ODVA: High CPU usage performance problem
      Summary With this fix CPU consumption is lowered back as expected in previous version. Description With this fix CPU consumption is lowered back as expected in previous version. Issue Number: 248996 Fixed on Date: 2.3.2022 Versions: 8.20 0 BUILD ...
