StratonNG: String within structure variable in service engine does not receive value and status under specific circumstances
A variable of the data type String within a structure variable for the StratonNG driver receives neither value nor status in the Service Engine. However, a value can be written to the variable within the Service Engine. Other variables within this structure variable with other data types work as expected.
This behavior has been fixed. String type variables within a structure variable for the StratonNG driver work as expected again.
Item ID: 258889
Version: 10.00 Build: 113329
