STRATONNG driver. General request fail
STRATONNG-driver. General request fail => there are no values. The problem is that the driver does not get the required event. (DiagViewer)
 Improved timing behavior of unsubscribing and subscribing change of event list
Issue Number: 30226
Fixed on Date: 1.10.2013
Versions: 7.10 0 BUILD 7770
- Related Articles
- Checklist: Driver(s) cannot establish a reliable communication- Time estimate: 60 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick hints] ...
- Abnormal General Request Frequency After zenon Redundant Switch in CNet Driver- Description The CNetDrv driver General Request Frequency after a zenon Redundant Switch differed from the selected General Period (200 ms) time. The CNetDrv driver on the PC newly promoted to primary PC sent the general queries every 15 ms. The issue ...
- Checklist: Communication to TwinCat via BeckhoffNG driver- Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. TwinCAT ADS communication library ...
- stratonNG driver cannot read string variables- Summary In the version 1800 of the stratonNG driver string variables cannot be read anymore. An Element from type dynamic text stays empty. In diagnosis viewer (deep debug) you can see that the driver gets the value from zenon Logic runtime, but then ...
- Driver configuration cannot be opened and also no new driver can be created.- If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
