StratonNG driver does not support variablenames without prefix
As the startonNG driver supports multiple connections without having a net address for identifying the connection it uses the variable prefix. So this prefix is mandatory when using stratonNG driver. But we also offer a setting to turn the usage of the prefix off, in that cases the driver could not exchanged as there are mandatory settings missing then.
Added additonal option to use the symbolic address property for addressing.
When change Projects from straton32 to stratonNGdriver not using prefixes, need to use then the symbolic adress field including prefixes.
Issue Number: 28835
Fixed on Date: 2.4.2013
Versions: 7.10 0 BUILD 6571
Checklist: Communication to TwinCat via BeckhoffNG driver
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. TwinCAT ADS communication library ...
STRATONNG driver. General request fail
Summary STRATONNG-driver. General request fail => there are no values. The problem is that the driver does not get the required event. (DiagViewer) Description STRATONNG-driver. General request fail => there are no values. The problem is that the ...
PHOENIX32 Driver should support variable addressing via symbolic address
Summary PHOENIX32 Driver should Support variable addressing via symbolic address in addition to addressing via variable name. DescriptionPHOENIX32 Driver should Support variable addressing via symbolic address in addition to addressing via variable ...
stratonNG driver cannot read string variables
Summary In the version 1800 of the stratonNG driver string variables cannot be read anymore. An Element from type dynamic text stays empty. In diagnosis viewer (deep debug) you can see that the driver gets the value from zenon Logic runtime, but then ...
Driver configuration cannot be opened and also no new driver can be created.
If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
