Straton Workbench TLS settings are not correct stored
When creating a fieldbus configuration in zenon Logic, the settings for TLS are not saved correctly under certain conditions. When the configuration is reopened after saving, the configured settings have disappeared or no longer correspond to the configuration. This may be caused by a special combination of Windows language and region settings.
This bug has been fixed. Fieldbus configurations with TLS are saved correctly again.
Item ID: 279586
Version: 14.00 Build: 239777
    • FAQ: Which CSPRNG is used by OpenSSL in zenon, for e.g. TLS communication?
      The OpenSSL version used in zenon is the LTS version 1.1.1. On Windows systems OpenSSL in zenon makes use of the Windows Cryptography API: Next Generation (CNG). For generation of random numbers and seeding of the random number generator, ...
    • straton Workbench / Logic Studio: Password can not be set/reset anymore on UDFB
      Description In Logic Studio, the password can no longer be configured for programs of type "UDBF". It is no longer possible to open the "Security" tab in the "Properties" dialog for these programs. An error message indicates that this name is already ...
    • zenon logic: Unexpected complex data in expression
      In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
