Straton to zenon Runtime connection handles special characters in variable names wrong (cross effects on name related variables in Runtime)
Straton to zenon Runtime connection handles special characters in variable named wrong (cross effects on name related variables in Runtime)
dots are no longer replaced with underlines in the variable names
Issue Number: 30483
Fixed on Date: 2.10.2013
Versions: 7.11 0 BUILD 10238
Metering Point Administration does not work with variables with Special characters in their names
Summary The Metering Point Administration creates some zenon logic code to calculate the relative values. However, if either the absolute value variable or the relative value variable has special characters (like ä, ü, etc.) in its name, then the ...
OPCUA32: Driver does not correctly import variables with special characters
Summary OPCUA32: Driver does not correctly import variables with special characters. Variables are offered for import but do not communicate correctly during runtime due to incorrect characters in the addressing information. Description OPCUA32: ...
BACnetNG: while using trend logs, if a variable with wrong object name is being requested and the driver can´t retrieve any data, all following variables are skipped
Description For the BACnetNG driver, if trendlogs from a variable with an incorrect object name are requested and can not be received, all following variables from the same device will not be requested. This issue has been addressed and the following ...
straton strings with special characters are broken in force value dialog
Description In zenon Logic, strings with special characters are not displayed correctly in the Spy and in the Force value dialog. String values that are forced are not correctly written. This bug has been fixed. The value is displayed and written ...
