Status update problem in the KABA-Driver
If the status (e.g. AlarmID, AlarmText, State) getting updated once (Door opens and then closes) the status does not switch back to the actual status. After the status change from the door the status has: '-1' which means unkown. It is needed to restart the runtime to display the actual status again.
The problem was addressed in the data change part of the driver. Now the value change event sent from the KabaDPServer is used to update.
Issue Number: 34588
Fixed on Date: 11.6.2015
Versions: 7.11 0 BUILD 20530 | 7.20 0 BUILD 20544
