Starting the zenon logic runtime standalone through command line parameters does not work correctly on Windows CE
The zenon logic runtime cannot be started correctly through command line parameters on Windows CE when the PATH= parameter points to a directory that contains a space.
An issue has been addressed in the zenon logic runtime where the PATH= parameter was not correctly interpreted when the directory path contained one or more spaces. Now the directory path can also contain spaces.   usage example: "\hard disk\rt\STRATONRT.exe" -PATH='\hard disk\prj\'
Issue Number: 10932
Fixed on Date: 3.12.2010
Versions: 7.00 0 BUILD 0
    • Checklist: Update CE fails
      Time estimate:   15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • FAQ: Windows CE not supported anymore with zenon! What are the main reasons and what do I have to consider? Is zenon not able to run on Windows CE anymore?
      The support for zenon Windows CE Versions was frozen with the zenon Version of 7.20. This means that in any higher zenon version, the CE Version delivered with the Setup is a zenon CE Version of zenon 7.20. There are no more functional enhancements ...
