The SQL evacuation stops if in the archive file are two identical values. Identical means same NameID same Value same Timestamp same Status. These entries could happen if in the archive configuration the option 'save process image during start OR end' is activated.
If an integrity violation occours (Error 0x80040E2F) the record is skipped and not stored in SQL a second time and a log message is created.
The fix is tested for SQL Server provider. If an ODBC provider is used you may end up with the same problem before the fix. The error message in that case would be: "Execute INSERT statement failed 1, hr=80004005"
To solve this error, change the provider to SQL Server provider.
