SOT replacing rule does not work after change on SOT if SOT is referenced in other SOT
A Smart Object Template (A) is referenced in another Smart Object Template (B). After changes in SOT A, the already existing Smart Objects of SOT B are unusable. Screens no longer work. However, newly created Smart Objects work as intended.
This error has been fixed. Screens work correctly in Smart Objects of referenced Smart Object Templates.
Item ID: 262148
Version: 11.00 Build: 157700
    • Renamed references do not rename zenon logic programs when updating the SOT
      Description In a project references of a Smart Object Template (SOT) are renamed. When updating the SOT, zenon Logic programs are not renamed accordingly. The original names are still included. This behavior has been changed. When renaming ...
    • Password change at first user logon works via operating system but not via zenon SE ; no AD login possible
      Description In the Edge Gateway frontend, the user password can no longer be changed in MS Active Directory, when the zenon system is not a member of the domain. Despite correctly entering the previous password and the new password including password ...
