Some statistics variables of the DNP3_TG master driver are not updated when objects groups are received from the outstation
The statistics variables "unsolicited response objects received" (offset 907) and "solicited response objects received" (offset 906) of the DNP3_TG DNP3 master driver are not updated when the master receives object groups from the outstation. The statistics variables remain at value 0
 An issue has been addressed in the DNP3_TG master driver where object groups received from the outstation did not correctly update driver statistics variables. Now the driver statistics variables are correctly updated and incremented for every object group received, in responses or unsolicited responses.
A binary input packed format with time, may transport up to 8 binary inputs however at the protocol level counts as two objects (G1 and G50)
A analog input with time (variation 3) counts as one object as time is integrated and not included as a separate G50 object.
Issue Number: 35057
Fixed on Date: 9.11.2015
Versions: 7.60 0 BUILD 36068
