Some scenario with JSON functions crashes the runtime
zenon Logic is terminated unexpectedly under certain circumstances. This happens when the "JsonWriteTxb" block is used.
This error has been fixed. The implementation of the "JsonWriteTxb" block has been adapted. This block can now be used in zenon Logic as expected.
Item ID: 273165
Version: 12.00 Build: 206562
    • Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
      Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
    • JsonMemberName() crashes the runtime if argument is not a member (no member name)
      Description In zenon Logic, the logic Service crashes if the argument for JsonMemberName() is not a member. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the latest build of zenon 14 or higher. Item ID: ...
    • CD_SVA_2025_01: zenon Remote Transport Vulnerability
      What you should know The vulnerability targets a specific function of the zenon Remote Transport Service. The underlying weaknesses is CWE-306: ‘Missing Authentication for Critical Function’. The versions listed below are affected by this ...
