Some drivers, e. g. MODRTU32, cause the zenon Logic runtime to show unexpected behaviour when running as IEC 61850 server when the driver connectes to the listening port of the IEC 61850 server within the zenon Logic runtime.
When the zenon Logic runtime is running as a IEC 61850 server, the connection attempt of some drivers, e. g. MODRTU32 to the listening port of the IEC 61850 server within zenon Logic results in an unexpected behaviour of the zenon Logic runtime.
This issue has been addressed by implementing a check to consider only telegrams of the IEC 61850 protocol.
Issue Number: 38572
Fixed on Date: 20.7.2017
Versions: 7.50 0 BUILD 39729 | 7.60 0 BUILD 39532
    • Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
      When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
    • FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
    • Checklist: OPCDA Server
    • zenon Logic shows unexpected behaviour after several redundancy switches.
      Summary After several redundancy switches, the zenon Logic runtime shows unexpected behaviour. DescriptionAfter several redundancy switches, the zenon Logic runtime shows unexpected behaviour. Solution This issue has been addressed by not accessing ...
