Some alarm attributes do not have a current value in the OPC UA server in the process gateway
With the OPC UA server in the process gateway, some alarm attributes of an alarm object do not have a value even though an alarm has been active prior to the point in time where the OPC UA server was started.
 An issue has been addressed in the OPC UA server where some alarm attributes did not have a current value even though on startup of the process gateway with the OPC UA server an alarm had already occurred. Now the attributes are filled with the values of existing alarms.
Issue Number: 30333
Fixed on Date: 2.12.2015
Versions: 7.60 0 BUILD 36068
