SO variable mapping rule should be applied when pressing 'Apply' not only when exiting the dialog w/ OK
When an Smart Object variable mapping rule is applied to an existing Smart Object instance via the API, the variable mapping is not saved. It is only saved if you manually open the variable mapping dialog and click “OK”.
This has been fixed and the rule is now applied when using the API method “apply”.
  • Update your zenon Software Platform to zenon 12 or higher.
Item ID: 267162
Version: 12.00 Build: 162090
    • SO - Rule-based variable mapping
      Summary Smart Objects allow rule based variable mapping. Description Smart Object variables are now consumed in Engineering Studio and Service Engine for the licensing. The order of the rules for variable mapping can now be changed manually. The ...
    • Smart Object API : Variable mapping not applied after changing in engineering studio
      Summary Changes in the variable mapping of a Smart Object instance are not applied during CSV export via SmartObject Export Wizard. This behavior has been changed. Description For a new Smart Object instance, variables are mapped in the Engineering ...
    • Web Engine: symbol linking rule is not applied to nested symbols
      Summary Variable and function substitution is now applied recursively in the web engine. Description Variable and function substitution is now applied recursively in the web engine. Information Do not use nested symbols in Web Engine projects. Issue ...
    • incorrect language for OK and Cancel buttons in the rename step dialog
      Summary In Batch Control Matrix recipes it is possible to rename the steps. Doble clicking on the step will open a dialog to enter a new name. The content of this dialog is displayed in zenon's defined language. Only the the buttons OK and Cancel use ...
